randywebb's Avatar
Oil Line Routing
in the pic, are these oil hoses routed correctly? I can't seem to get the straight hose to the tank to go on the outside, nor can I find a photo in the shop manual that shows me how they ought to be. So, I'm concluding that the line with the curved metal end (that goes to the metal 'hoop' shaped line that crosses the engine) is the one that ought to be on the outside -- as shown in this pic. True??
The problem is that I discovered that the tire abraded the hose a bit. That could be from my failure to be able to get the hoses up high enough and in close to the body enough -- I was never able to get them up high enough to use the correct mounting hardware -- even after I put a bottle jack under them to lift (with a wood pad on it).
I realize the lines are too low -- I haven't tried to wrestly them up to where they belong yet...
but is the proper hose on the outside?
Old 04-30-2006, 12:12 PM
Wer bremst verliert
JohnJL's Avatar
Randy,
On mine the line to the engine goes up-and-over the line doing directly to the tank.
I have some QT video clips of where my hoses are routed by e-mail if you want.
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-30-2006, 01:41 PM
cycling has-been
bkreigsr's Avatar
the one that crosses under the bellhousing is on the inside
there's a good pic in one of Wayne's howto sections. just can't remember which one, or maybe the PP catalog under 'oil lines'.
Bill K
Old 04-30-2006, 02:33 PM
randywebb's Avatar
Nope not in the catalog -- my car is a 1973 if that makes a difference. Not sure what the over means in 'up and over'...
Bill -- are you saying the above pic has them in the wrong orientation relative to your '73 911 MFI 2.5L car?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-30-2006, 02:52 PM
cycling has-been
bkreigsr's Avatar
no, sorry Randy. I don't have auxilliary oil cooler in my 73. I was referring the the orientation in my 77. I'll find pic later tonight or tomorrow.
Old 04-30-2006, 03:06 PM
Vin-barrett's Avatar
Heres what mine look like
-Vinny
1983 911SC
Old 04-30-2006, 05:20 PM
Tom '74 911's Avatar
Dang, I just went out to the garage to snap some photos and Vin beat me to it!
Anyway, here's mine:
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 04-30-2006, 05:29 PM
randywebb's Avatar
Thanks - it's good to have 2 cars posted! Reason: a PO might have altered a car, but it is unlikely that several PO's altered several cars n the same way...
Now, I just need to figure out a way to get a sheet metal screw in to hold that bracket shown in the photos on... no luck after 4 hours of struggle today...
Old 04-30-2006, 06:03 PM
Randy -
My bracket is attached via a threaded stud that's welded to the sheet metal - or maybe coming thru from the other side w/a 10mm nylock nut that you can see in the photo (kind of).
Tom
Old 04-30-2006, 07:52 PM
randywebb's Avatar
Huh - that would be a good way to do it. On my car there are 2 places where there seem to be small plastic inserts - they look sorta like "Mollys' that you use in drywall in a house. Some kind of sheet metal screw is supposed to go in there. I guess... I don't really know as the PO had an odd rig going in some places, and then the painter painted over the small inserts. But that is my best guess.
Maybe I can get to the other side and just drill a hole and put a bolt thru...
Old 04-30-2006, 08:59 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Here is how to not route the lines. The one with the metal part was twisted so that my tire rubbed right through it: Alot of smoke & oil (could have been worse)
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 04-30-2006, 09:03 PM
randywebb's Avatar
Hmmm - what was wrong with the routing? I t just looks like it was too high...
Old 04-30-2006, 10:28 PM
ischmitz's Avatar
Yep - that's what I meant. The bent metal part pointed up too far causing the rubber line to get pushed out by the longitudal member and the tire did it in....
Old 04-30-2006, 10:49 PM
Wer bremst verliert
JohnJL's Avatar
Huh...both late (and guards red!) sc's have different routing to mine...can't post pics here, only have a short video clip.
Old 05-01-2006, 03:12 AM
randywebb's Avatar
Part 911.207.237.00 - support bracket - $10.52 @ Pelican is a smaller version of the same mounting bracket as the 3 that used under the rockers. It is shaped exactly the same and mounts in the rear fender well with a sheet metal bolt thru it - the wings hold the 2 oil lines with rubber hose wrapped around them to cushion them.
I should say the above is what is supposed to happen - I can't get it to mount on my car.
Old 05-07-2006, 05:58 PM
