-   -   Oxygen Sensor Connection (http://forums.pelicanparts.com/porsche-911-technical-forum/280833-oxygen-sensor-connection.html)
Amanda 05-03-2006 08:29 PM
I put in a new O2 sensor today, but the thing to connect it to in the engine compartment looks like this (sorry for blurry image):
http://mike.acosta.net/images/o2conn.jpg
The orange plastic is broken, and I'd like to replace it. Does anyone know what part this is or what I need to do to repair/replace this? Thanks.
Grezdlitn 05-03-2006 09:36 PM
Mine looked just like yours. I was unable to find a replacement so I broke the brittle plastic away and trimed the wire. You must take some care as the wire(green in color) is a coaxial.
Amanda 05-04-2006 09:23 AM
OK, thanks for the reply. I'll try that...unless anyone ever replace this?
wswilburn 05-04-2006 07:07 PM
You might find someone who has done an EFI upgrade and gone to a heated O2 sensor.
sammyg2 05-04-2006 07:37 PM
That is part of the wiring harness and is not easily replaceable. just clip it back and replace it with a new connector.
BUT.... the green wire going to the lambda brain is coaxial, do not connect the outside wires, only the inside or middle wire.
Jesset100 05-05-2006 08:17 PM
Mine looked like yours.
http://forums.pelicanparts.com/uploa...1146885210.jpg
