dweymer's Avatar
rear wheel bearing race removal ??
I pulled my hubs out for my rebuild, and one of the outer races stayed pressed onto the hub, how do I remove that? My puller needs something in the middle to press against but the hub is hollow.
Donnie
Currently Porsche-less.....
Old 05-04-2006, 09:41 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Use a dremel and cut 2 slits lenghtwise (parallel to shaft), 180 degrees apart, almost through the race (no touchy hub).
Mount hub in vise, and crack race open with cold chisel and mini-sledge.
Take a peak at what a local (p-car) shop did to my hubs with an air-chisel. I learned the hard way. The above method works well.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 05-04-2006, 10:13 AM
Use a bearing splitter/ spreader which cost about $20. There is a tech artical here on rear bearing replacement.
http://www.schattenbaum.org/
ED
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 05-04-2006, 12:21 PM
