Queston on oil line wrenches
Guys- I was just about to push "order" on the set of large oil line wrenches that Pelican sells, and I stopped because I noticed this:
Whould anyone recommend this over the set with the 36MM in it? Or should I just get the set?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
it has advantages & disadvantages. I have both and usually use the regular ones.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
RETIRED
Nice to have the Porsche wrenches, but I have been able to get by with the thin Campagnola bicycle wrenches made for headsets. I inherited them and they have been fine.
The Park brand are cheap and work as well. YMMV
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Pelican should start carrying Campy stuff...
RETIRED
Nobody said Campy stuff was cheap.....
I agree, don't order the campy stuff.
Buy the pro quality wrenches, invest in a can of PB Blaster. Don't break your car. |
If you are replacing the lines, the best way to go is to use a dremmel tool with a cut off wheel. Cut 99% of the way through the nut, being careful not to score the threads. Insert a large flat head screwdriver and snap the nut. The wrenches used to remove these lines often put much more stress on the components they are attached to and can cause damage to a much more expensive part than an oil line. I also don't recomend heating the nut with a torch as these lines carry oil, and oil is flamable.
I just replaced the two rear oil lines going to the thermostat. I think you have to have a variety of wrenchs for any job, as I used the Pelican wrench (36mm oil line wrench) and a crecent wrench depending on location. Up front, working on the fender oil cooler lines, I used a 30 or 32mm combination wrench, as needed as a counter in addition to the Pelican wrench.
BTW, a 36mm combination wrench is huge compared to the Pelican wrench. I made a cheater out of some metal tubing to go over the end of the Pelican wrench to give me more leverage as needed. |
