please shed some light on '87 H5 headlights...
Though well-intentioned, to be sure, the last time I posted a queston about my headlight swap, I got just about everything except what I needed. My swap is "factory H5's" ( like an '87) to "EURO" H-4's ( not those sugar scoop-Hella things). I'm told that I needed new plugs to work with the H4's (which take a 9006 bulb, the H5's took a 9004 bulb). since the trim rings look similar, I asked if the originals ( already painted) would work, and I also asked if anyone had done this lately and hopefully someone would be able to tell me what would need to be done as far as replacing/rewiring the plug to work with the H4's ( for the 9006 bulb).
Old 06-14-2006, 06:04 PM
H4's take..... an H4 bulb....
Euro H4 = Bosch H4.
Converting H5 to H4 requires a new plug to accept the unique pin-out of an H4 lamp assembly.
Trim rings for H5 don't work for H4.....
This stuff ( believe it or not)...is indeed in the archives under a search. Try different sets of obvious key-words.
-Wil
EDIT: did you come across this --> H-1 H-2 H-4 H-5 ???????
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-15-2006, 07:17 AM
Nine9six's Avatar
Some autoparts stores carry the H4 plug...Same as old VW. If the standard auto parts stores dont carry, go to a vw speciality shop; they'll have em.
DO NOT FORGET! you will need to install relays to handle the H4's. Do a search on "Sucro". Otherwise the current will weld the hi - lo contact switch in your stalk.
Marcus Sucro sells a kit with simple instructions so even an electrical moron such as me, can install them.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-15-2006, 09:23 AM
Euro H4 = Bosch H4.
-Wil
I tried all that, but this one addresses exactly what I was looking for. Off the the FLAPS for a couple of H4 plugs and GP white paint for the black primered rings, and I will have traded my cracked factory dim sealed units for brighter, cleaner looking H4's that I can blind deer with at 200 yards. Thanks, guys!
Old 06-15-2006, 10:35 AM
