Oil Light - Green - What does it mean?
Green Oil Light - 74 911
I got my car back from the body shop. The Oil indicator is GREEN. I did not have this condition before. I do have a two wires that are loose. They are in the rear by oil tank. The three sensors -(1) rear driver side and (2) read passenger side have wires attached.
Help is greatly needed. Wires? What sensor controls the Oil Green Light?
Old 08-07-2006, 07:40 PM
Bollweevil
The sending unit for the low oil pressure warning light is located on the top / front of the case just in front of the CIS. The body shop may have damaged the connector or the wire somehow. Access to the unit is pretty much by feel or you can see it with a mirror and flashlight.
http://www.pelicanparts.com/911/911_Parts/1974-75/1-1-2.JPG
Part # 49 in the diagram
Jack
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 08-07-2006, 08:58 PM
