justinbaldwin's Avatar
Overheating
hi,
my 82 SC seems to be overheating. on a short town drive at normal speeds my temp was reaching the upper white temp mark, when i got out i could smell oil burning off the engine (leaking return pipes). i've no doubt that it would rise further on a longer trip.
the oil is at the correct level and the engine has a new and properly adjusted fan belt, and i haven't lost a rag in the engine.
i'm not sure what else might be causing this?
any thoughts most welcome
regards
justin
1982 911 SC 'Paloma'
1989 Mercedes W124 250DT (inferior substitute for the U-boat)
1998 Honda CBR900 RRW, (gone but not forgotten).
1982 VW Scirocco 'Roger', (took my youthful abuse with complete aplomb)
1969 Daimler 420 'Agatha' (why did i ever sell the old girl?)
Old 05-05-2006, 03:39 PM
ianc's Avatar
Put your hand on the metal oil lines on the passenger side of the car down near the rocker panel. If they don't seem warm, your thermostat is not opening and will probably be the first thing to look at,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-05-2006, 04:02 PM
Location: Midlothian Texas about 20 miles south of Dallas.
Have you checked the timing or changed it recently? A improperly timed engine has a dramatic effect.
Mark
1981 911SC Sunroof Coupe
2005 Volvo XC-90 2.5T
Vans RV-8 Experimental Aircraft
Old 05-06-2006, 12:05 PM
Work in Progress
Rich76_911s's Avatar
The first thing that I would look at is to check and make sure that my engine mounted oil cooler was clean. Caked on oil and dirt can cause the efficiency of the oil cooler to decrease. Second I would check the thermostat(s). There is one on the engine, and the second one is in the rear fender behind the passenger side door. I've heard that you can check the engine mounted thermostat by taking it out and placing it on a hot plate to see what temperature it opens at. I've never done this though so take it with a grain of salt. Those are my ideas
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 05-06-2006, 01:38 PM
