Hey Sherman,
Can you post a pic of your connection from the finned return line to the bottom of the oil tank? When I test fit this, it was the one part of the assembly that looks to be a really tight fit. The hose I made, which is extremely short, is going to be stressed when final-assembled. Any thoughts on this? How did it work out on your car? |
I havent cut or fit the flex hoses yet, only mounted the lines. You are right, its going to be tight to fit the short line to the tank. My plan is to 90 upwards off of the line with one of Chuck's factory fittings and to use the straight fitting to hook into he tank. I haven't measured it yet, but the piece of hose off the 90 probably wont be 4". I'll bump this thread when I get everything cut to length and test fit..
Im glad I went ahead and spent the money on the lines. Its going to be a pretty clean install when its finished. |
| All times are GMT -8. The time now is 04:00 PM. |
