16" Track Wheel Options
I'm in the market for a set of 16X10.5 and 16X13 track wheels. The options I know of are Fikse and Kinesis. What else is out there?
Thanks- Craig Backer |
kodiak wheels
http://www.kodiakracingwheels.com/wheel-prices.php If interested in them, send Catca (Jeff) a pm or e-mail. Jeff is a dealer for Kodiak wheels.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
I checked out the Kodiak websight but couldn't figure out how much the wheels weigh. Any idea if they're light (ie. under 20 pounds).
I also just realized that Fikse and Kinesis don't make 16" wheels. Thanks- Craig Backer |
Even 17s have limited selection. Jeff would know their weight I think. I'd guess they're similar weight to Fikses and Kinesis....if they still made 16s.
MBruns for President
yes kodiak are under 20 - also try ccw wheels
http://www.ccwheel.com/files/home.php http://www.mirageintl.com/parts/otherracecomp.htm http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=GENWHEELS
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
16" race wheels
Don't forget Jongbloed Racing wheels.
www.Jongbloedwheels.com Just ask for the size and offset you'd like and they will make a set for you. Super light weight. Bob |
Non Compos Mentis
Fikse no longer makes 16s.
They will be under 20 for sure, I will double check this week on it. There is some variable in the weights as well depending on how much brake clearance we need. That effects the thickness of the center section mounting "pad" (for lack of a better term) which in turn effects the weight. Stock brakes will equal a lighter wheel. It is not a huge variable at all, infact it is minimal, but a variable none the less and I thought I should mention it. The target weight on the 17's (7.5/9) is around 16-17 lbs, so I would think the 16's would right about there as well.
More info to follow. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The tire sizes that you are referring to is exactly the size that we run on our track car. We use REAL racing wheels shod with Hoosier slicks. You can visit our website at www.almost.co.za for more pictures and details on our setup.
Regards
Johan www.almost.co.za |
Bird. It's the word...
Simmons are another nice 16" option.
John Forcier Current: 68L 2.0 Hotrod - build underway |
