kpfoten's Avatar
A good day for my mid-year!
Well, after a year or so of fussing with an engine that would die when braking for stoplights, bizarre idle, etc, I finally took the plunge and removed my CIS and replaced all the gaskets, o-rings, and intake runner hoses.
I think the main sources of my airleaks were the CSV o-rings and the lousy old warped intake runner hoses (I think that's what they're called anyway).
I cleaned everything up, and for yucks even painted around the seam of the airbox (even though I couldn't find any cracks!) with some epoxy from West Marine.
Put everything back together on friday and started her up--the fuel mixture was way off (HOORAY!) like by 5-6 full turns of the screw. Dialed it in and I was good to go!
I've been driving it for a few days now and the idle is steady no problems whatsoever... Keeping my fingers crossed.
In all, about 2 hrs to remove the CIS (didn't even have to do a partial drop!), about 3 hours of cleaning and replacing parts, and another 3 or so to re-install.
Time well spent!
Kris - '77 911S
Old 05-07-2006, 07:01 PM
ianc's Avatar
Nice job! CIS works well if clean and well-sealed. Enjoy it,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-07-2006, 07:14 PM
Designer King
Paulporsche's Avatar
Good work!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-07-2006, 07:41 PM
9elf's Avatar
kpfoten,
Please help. Which o rings are you talking about exactly? I am about to do exactly what you have done. I have organised the intake runner rubber sleeves, and a new set of intake gaskets from our host, but I haven't planned for any o rings.
Anything else that I should order? I'm in Australia so I need to plan ahead.
Thank you.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 05-08-2006, 02:22 AM
kpfoten,
It sounds like you did exactly what your car needed - great job!
9elf,
For my car, the CIS parts that were in the worst shape were the following:
The injector o rings = 999-701-423-40-M16
The injectors are mounted in plastic sleeves that get hard and brittle with age = 911-110-886-03-M260
These sleeves also have o rings = 999-701-446-40-M17
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 05-08-2006, 05:14 AM
kpfoten's Avatar
9elf:
I found that my cold-start injector o-rings (The inner and the outer plenum) were in awful shape. The inner one is available from Pelican (forgot the part number) but the outer one is NLA. I got something real close (It wasn't metric) from a local auto parts store.
I also changed the gasket which mates the fuel distributor to the airbox.
Good luck--let me know if you need any advice.
Kris - '77 911S
Old 05-08-2006, 07:13 AM
These O-rings and injector sleeves are all removable? I remember that the sleeve seemed to be swedged into the intake runner the last time I had it apart.
Dave
'75 911s Coupe
Old 05-08-2006, 07:56 AM
9elf's Avatar
Thank you kpfoten and Walter Middie.
Old 05-08-2006, 10:58 AM
