sean m's Avatar
sump plate kit won't fit??
Bought the sump plate kit from Pelican for my '77 911s. Thought it would be great to change oil without having to remove the whole plate every time. Anyway, removed the old plate and found it has a screen that is rounded. New plate from Wayne is flat and won't fit. Do I need to remove the screen to make this work or did I waste $80.00?
Old 05-08-2006, 05:31 AM
I bought the MCD-993-107-001-00 for my 78sc rebuild with carrera oil pump. It works greatand fits well. Which one did you order. Mine has a deep well that allows for clearance.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 05-08-2006, 07:40 AM
sean m's Avatar
I got the exact same one, however, this won't fit on mine due to the screen at the bottom of the engine. Obviously, you didn't have to remove the screen. I don't get it. In the description on Pelican it say's will fit mine but it's not close.
Old 05-08-2006, 07:56 AM
sean..I recall the inside of mine being dished out. the center section is about an inch deeper then the flange. I might have purchase the plate directly from Mainely:
http://mainelycustombydesign.com
Looking thru their website its clear that I ordered: 993-107-001-00
ck out their picture:
http://mainelycustombydesign.com/1sump9.html
Peace, Ron
www.ronorlando.net
Old 05-08-2006, 11:13 AM
sean m's Avatar
Mystertrain.........that's it. I can see the difference. Now what to do with the one I can't use!
Thanks for the help.
Sean
Old 05-08-2006, 11:30 AM
Fud Fud is offline
Fud's Avatar
Hi Sean, Yes, you will need our 993-107-001-00. It's designed to replace the rounded cover, that does not have the drain plug and is used with the upgraded turbo oil pump. The 993-107-001-00 has the round inside and uses the 911 drain plug.
It might be easyer if you email me your shipping address and I'll exchange yours for the correct one that you will need.
Bob Futterrer
Mainely Custom By Design, Inc.
sales@mainelycustombydesign.com
Bob "FUD"
Mainely Custom by Design
65 356C (Outlaw)
76 912E
2000 Boxster
Old 05-09-2006, 04:38 AM
wow..good man Bob!! I got to say I love the cover and it sure makes life easier!
Peace, Ron
www.ronorlando.net
Old 05-09-2006, 06:16 AM
sean m's Avatar
Thanks again Bob.......I'm still a "newbie" and learning every day. I have allot more to do to my car over the next few months.
I appreciate your follow up. I'll certainly use and recommend Mainely Custom in the future.
Sean
Old 05-09-2006, 06:43 AM
