differences between 964 & 993 longblocks???
Just wondering what the differences between the early and late model air cooled 3.6 longblocks are?
Thanks- Craig Backer |
Obviously the crank rods and pistons are different, the 993 has the block mounted oil filter which can be adapted w/ some difficulty to the 964 block, the heads are a different alloy, ports and valves are smaller on 964.
Thanks- CB |
take a look at Aichele's engine book & at Frere -- at some point they used CAE to redesign the valve train and reduce recip. masses
| All times are GMT -8. The time now is 01:39 AM. |
