one bright one dim h4's
I have a 73.5 w/ a drivers side bright head light and passenger dim head light. It is brightens a bit when throttle it pressed. Thends to be dim most of the time.
Is it a bad ground or bulb. Preferably an easy fix. Dave
Gemini Blue 73.5 911 T Sold 1994 C4 Widebody Sold |
You have a bad ground to the the dim one
We're only here for a short time, so lets have a good time! J. Buffet |
Thanks,
I'll check it today. Dave
RETIRED
Mine ended up being a defective bulb....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
You have the ground and power lead reversed on one of your bulbs. I have been there done that
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
RETIRED
Swap bulbs or put in a spare first.....don't touch the bare bulb. The oils from your fingers/hand create a hot spot.
