LinkBack | Thread Tools | Rate Thread |
			 Rennch on YouTube
				What does the ground wire that attaches at the coil bolt connect to?
			I am in the garage doing wiring...I thought I might get a quick answer if I posted the question in the subject.
	Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/  |
			In a stock car, the brown curly wire goes between the coil negative terminal and the fan housing.  You then must have a ground strap between the fan housing and the engine block for the coil to work.
	'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20)  |
			 Rennch on YouTube
			John,
					thanks for the info. I'm running an MSD AL6 and MSD Blaster coil. The MSD has a + and - running from the unit that plugs into the coil. It figures the ONE picture I didn't take is that connection...does it maybe still tap into that negative terminal on the coil, or should it perhaps go to the MSD somewhere?
