Bearing question quick! Pls help!
Quickie - I have the hub on now: Fill the cavity between the inner and outer front wheel bearing swith grease or leave empty. What about th dust cover? Fill or just 10g?
Thanks!!!!
-Brian
Old 05-10-2006, 07:53 PM
jpahemi's Avatar
Cavity empty; did that once and the hub had a hard time turning. Imagine when the grease heats up and expands!! Put a small lip of grease on the edge of the cap to supply fresh grease to the smaller bearing.
j.p.
Old 05-10-2006, 08:00 PM
Okay, that's what I thought, thanks. I did put a heathy bit between the inner seal and the inner bearing as Bentley states. I feel better now. On it goes!
-Brian
Old 05-10-2006, 08:02 PM
All bolted up. Tighened the nut until I could barely wiggle the washer with a screwdriver. Can one tell when driving if it is too tight or too loose before a new bearing is ruined?
-Brian
Old 05-10-2006, 08:42 PM
