SP2 SP2 is offline
SP2's Avatar
Rear Shock: What does AFM mean?
Hi, I could use your help. I am trying to replace my rear shocks. I did a search and found this under "rear shock removal". I have an 81SC that loves its new front Bilstein Sport inserts and is looking for its rears now. I am stuck at the removal of the top shock nuts. I know this has been addressed before. I found the post below under a "rear shock removal" search.
"Originally posted by 450knotOffice
Well, my Porsche mechanic buddy just came over to drop off a pressure bleeder for my brakes and I asked him what he would do. He told me that the easiest way was to simply remove the AFM and box as a complete unit. He said it's easier, quicker and offers more room to work as well. So that's what I'll be doing tomorrow.
Man, who would've thought it'd be such a PIA to pull one shock out. Sheesh. "
What does AFM mean? Can somebody post a picture or reference one showing me what nuts and bolts I should remove? Does this removal really only take 10 minutes? I spent much more time already at failing to remove the upper shock nuts.
Thanks.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 05-12-2006, 10:55 AM
Immature Member
dentist90's Avatar
Air flow meter... metal box between air cleaner and throttle body. Sorry, no pics handy
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-12-2006, 11:00 AM
PRO Motorsports
Tyson Schmidt's Avatar
I thought it was another name for the FSM, or "Flying Spaghetti Monster".
AFM= "Almighty Flying Meal".
On second thought, maybe it is the airflow meter.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-12-2006, 11:12 AM
jdowty3's Avatar
Maybe he's think you have a 3.2 instead of a 3.0 with CIS. The top nuts are hard to get at but not impossible. It's easier if you remove the heat blower motor to get at the drivers side shock. You could also remove the air-box piece ( black ribbed heavy rubber peice shaped like a kidney bean) that connects the throttle housing to the fuel distributor to help see the right side. You could also do a partial engine drop.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 05-12-2006, 11:25 AM
SP2 SP2 is offline
SP2's Avatar
Thanks for the replies!
I will read up on the AFM in Bentley and the P-workshop manual tonight.
James
1981 911SC Wine Red
Old 05-12-2006, 12:27 PM
chrisp's Avatar
Just did mine the other day. All I needed to do was to pull the accordian hose coming from the fan hosuing into the heater blower. That gave me great access to the driver's side shock. The passenger side was more challenging but without removing anything (I don't have A/C) I could wiggle my overstuffed arms and hands in such a way that I could get the nuts off. Good luck.
'83 SC
Old 05-12-2006, 01:11 PM
Immature Member
dentist90's Avatar
I have also come to the conclusion that in order to be a Porsche factory mechanic you must be able to shove your hand through a toilet paper tube without tearing the sides. MAN they can cram stuff into this car!!
Old 05-12-2006, 01:26 PM
rear shocks install
changed mine , just remove accordian hose from drivers side,passenger side top fastener a little difficult but was able to get at it even with big york compreessor in the way the hardest part for me was the lower bolts! no air tools had to use much force and a very long breaker bar ! very satisfying job esecially if the old ones were toast like mine! enjoy!
Old 05-15-2006, 10:59 AM
