si Banker's Avatar
Muffler Bracket
If you have back dated your exhaust system and are running an after market muffler I would like your feed back
This bracket is sandwiched between the heat-exchanger flange and the muffler flange, (you will need two sets of exhaust gaskets), and is attached to the rear engine mount by a separate bracket.
Because the distance between the two exhaust flangees are different on each exhaust system it would be necessary for the installer to locate and drill four holes to complete the installation. These holes would be used to attach the two brackets to the third bracket, not shown, which would be attached to the rear engine mount.
The bracket is made from .250 T6 6061 aluminum and is anodized for protection.
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 05-10-2006, 06:35 AM
Interesting design. Not sure about it being made of aluminum due to heat factors.
My thought would be use a standard measurement for center to center on most mufflers(what we use) and then drill the holes ahead of time.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-10-2006, 08:10 AM
si Banker's Avatar
Bracket
The problem is that the distance between the heat exchanger or header flanges is a little bit different on every car. This bracket would work with your exhaust systems. The part that attaches to the rear engine mount is not in the picture.
I will post additional pictures. I have been using one on my car for about 6 months with zero problems
1987 911 Coupe
Old 05-10-2006, 08:18 AM
Yeah I hear what you are saying I just am not sure about endusers wanting to drill holes in there newly purchased CNC braket?
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-10-2006, 08:44 AM
Virginia Rocks!
VaSteve's Avatar
Re: Muffler Bracket
You'd need longer bolts as well. Not to be negative, but I'm not sure I see the point.
I just got a use Bursh from someone. 1 in 1 out. The three bolts that hold it to the pipe (cat) and the 1 bolt that holds it to the bracket which attaches to the engine metal were enough to support it. I don't really see what this does... Even the factory muffler I took off (all 50 pounds of it) doesn't require but a couple of thin straps. It appears to be a solution in search of a problem.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-10-2006, 10:23 AM
si Banker's Avatar
Bracket
It does not work with a 1 in 1 out. It is for a back dated system such as 2 in 1 out. I will post a picture of one installed
1987 911 Coupe
Old 05-10-2006, 10:35 AM
Virginia Rocks!
VaSteve's Avatar
Re: Bracket
No, I figured as much. I offered my experience as an example. It just seems redundant. I'd like to see a photo.
Old 05-10-2006, 10:55 AM
si Banker's Avatar
Bracket
1987 911 Coupe
Old 05-10-2006, 11:05 AM
si Banker's Avatar
Bracket
The one in the photo is a slightly different design. It does show the plate which is attached to the rear engine mount using the existing holes. The muffler bracket is then attached to the it.
1987 911 Coupe
Old 05-10-2006, 11:10 AM
Virginia Rocks!
VaSteve's Avatar
So..... Nothing actually touches the muffler in the middle of the car?
If not, why not? If so, then why are the "arms" needed? Also, if not, then does all this do is provide some additional bracing/structure to the whole set up?
It does look nice.
Old 05-10-2006, 11:17 AM
GFCC
Jeff's Avatar
Looks like a great solution to back dating heat exchangers or going with straight headers.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 05-10-2006, 11:19 AM
si Banker's Avatar
Bracket
As I said before, there is a variance in the distance between the two exhaust flanges from one car to another. By making the bracket in two parts there is the feature of adjust ability. The installer would have to drill four holes, two in each "arm". Both arms would then bolt to the plate
1987 911 Coupe
Old 05-10-2006, 11:26 AM
so this is just like the 914-6 brackets? thats what it looks like
Ben
89 944,85.5 944
914-6werkshop.com
Old 05-12-2006, 06:27 AM
