-   -   Replaced MY Front Hood Struts Today (http://forums.pelicanparts.com/porsche-911-technical-forum/282643-replaced-my-front-hood-struts-today.html)
mkimber 05-13-2006 05:29 PM
I finally got tired of my front hood hitting me in the head or using a broom stick as a prop for the '87 Carrera. Maybe this has been said already, but I highly recommend Bob Tindel's article in the Tech Info Center to anyone thinking about replacing their front hood struts. What could have been a long and frustrating afternoon (particularly installing the pin and retainer on the driver's side) turned into a rather straight forward DIY, at least for someone who is mechanically challenged more often than not.
felix_browne 05-13-2006 05:32 PM
the trick for doing this job is having a pair of needle nose pliers with a bend at the end (90*) for putting the pin in and the retaining clip on likely one of my most used tools. especially usefull on the driver's side.
mkimber 05-13-2006 05:41 PM
Looks like we used the same approach, Felix. I used a very long and slightly curved pair hemostats for the pins, and dental floss to tie to the retainers so I could find them if I dropped them into the "black hole" or they flying across the garage (Bob Tindel's suggestions).
rs6er 05-13-2006 05:56 PM
Wish I'd read that article. lol!
RDR911 05-13-2006 06:24 PM
I didn't read the article, but my wife has small hands, so she finished the drivers side for me, what a gal!
Driver Ed 05-13-2006 07:41 PM
I used hemostats for the pins, too, but didn't tie anything to the retaining clips. I was done in less than twenty minutes... or about an hour if you count the time spent looking for and then fabricating a new clip! http://www.pelicanparts.com/support/smileys/face76.gif
LakeCleElum 05-13-2006 08:33 PM
Agreed, the article was quite useful.....Was my 2nd hood upgrade...The first was from a Yardstick that finally broke to a piece of 1 X 4 lumber.......
rs6er 05-14-2006 05:55 AM
Any advice on doing the rear?
Driver Ed 05-14-2006 02:32 PM
The rear deck is essentially the same job.
movin 05-14-2006 08:50 PM
Couldn't you drill the mounting pins to fit cotter pins instead of using the PIA OEM circlips?
mkimber 05-15-2006 12:17 AM
Cotter pins sounds like a good alternative. Wayne's book also suggests using nuts and bolts.
Dantilla 05-15-2006 06:40 AM
I recently changed the passenger side, and since the hood would stay up on it's own, decided that the other new one is now for next time I change the passenger side only.
Driver Ed 05-15-2006 11:33 AM
I don't know how cold it gets where you are, but those things don't work as well when it's cold out and you may find you need both.
qlander 05-15-2006 01:34 PM
The idea of using dental floss is awesome. Wonder if it would work on nuts. Although the tolerances may be too small. Interesting.
Q.
rs6er 05-15-2006 01:42 PM
I figured that one out on my own after one of the clips fell into the abyss.
buster73 05-15-2006 01:46 PM
I'm finally done with hood struts and "lifetime" warranties. Converted engine and trunk lid to Carbon Fiber struts. Not planing to touch them again for the next 30 years.
