looking for 1971 911 fuel pump support
I'm looking for a rear fuel pump support for my 911, do you guys have any sources for it? I haven't been able to find it
Thanks Fred |
bump.
Anybody? |
Do you know what you are looking for? Do you seek a bracket that is hose clamped to the pump body and then attached via rubber mounts to a bracket welded to the body? Or are you looking for the bracket welded to the body? Parts Heaven in Hayward, CA is a possible source for used parts of these types. The rubber mounts are likely available new but the brackets may be NLA - the part number would have to be used to check availability.
I'm looking for the bracket that is welded to the body
Fred |
Hello Fred
You can buy it new from Porsche. The part number is 911 501 023 01 I just purchased one about 2 weeks ago. Best regards, Mark |
You do not have permissi
Kudos to Porsche AG for having the part available, for now.
It may also be able to be fashioned from some 1/8 strip steel, a Mig welder, a few thick rubber washers, and a bit of time. Disconnect the batterys and CDI box before any chassis welding, and don't have the ground on the opposite side of any greased bearings.
Meanwhile other things are still happening. |
