Information Overloader
Fender Cooler Wiring
Hello Gentlemen,
I am installing a fender cooler with fan on my '83 SC. Because the cooler does not have a thermoswitch, it will be manually operated only; with a switch on the dash somewhere. Can anyone lead me through the wiring for this step-by-step or point me to the correct post? I have the relay and relay socket sold by our host for this project per the 101 Book. The 101 book describes wiring for manual and thermoswitching. I want manual only.
Thank you.
Old 05-16-2006, 07:45 AM
I just wired up a Carerra cooler with the thermo switch this weekend using the info from this post by flintstone:
oil cooler fan thermoswitch
Compare that diagram with this one that I modified. By wiring the fan ground to 85 and then installing a switch which completes or breaks the ground (circuit) this should work.
Perhaps someone else will jump in and confirm.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 05-16-2006, 12:03 PM
This, my good friend, is exactly the info I needed. Thank you djdsc, kind sir!
Old 05-16-2006, 12:17 PM
