-   -   Please help me find this distributor part (http://forums.pelicanparts.com/porsche-911-technical-forum/283223-please-help-me-find-distributor-part.html)
jbell959 05-16-2006 12:46 PM
I'm sure I'm not the only one that has a distributor that is missing or has a broken connector on the side. This is the small black plastic connector that connects to the points on the inside (circled below). There is no part number for this piece and I can't find them anywhere. The early 2.0/2.2 distributors have a round hole and the later 2.4/2.7 distributors have a square hole. I could use one of each type if I could find them. Any help is appreciated.
http://forums.pelicanparts.com/uploa...1147808785.jpg
stormcrow 05-17-2006 06:47 AM
All that is is a bulkhead fitting. If you can't find one, what you could do is get a rubber grommet to fit the opening, make your connections for both sides and seal the remaining opening with black rubbertex.
The plastic serves as a seal to keep moisture/water out of the distributor.
"A Porsche does more then just go fast in a straight line"
jbell959 05-17-2006 04:25 PM
Hi Steve - That's an option but it's an early 2.2S distributor that I had rebuilt so I was hoping to keep it stock and nice looking.
jbell959 05-22-2006 04:03 PM
Nobody knows were you can get these???
stormcrow 05-22-2006 07:50 PM
I wonder if you might be able to get one off a VW distributor? Just a thought.
ianc 05-22-2006 11:05 PM
I think the VW ones are much smaller...
ianc
jbell959 05-31-2006 02:48 PM
Still looking ....
vizail 05-31-2006 03:07 PM
Jbell 959
You can also call MOTO R&R in Californa. They Specialize in Water pumps,Smog pumps and Distributors Restoration and Rebuilding.
You have a PM
VicSmileWavy
http://forums.pelicanparts.com/uploa...1149113200.gif
jbell959 05-31-2006 03:28 PM
Hi Vic -
They were the first people I called. He can't find it.
jbell959 07-07-2006 04:52 PM
Still looking for this part if anyone can help... Thanks
