Mono Ball Life
I have just purchased some elephant racing bushings to replace the rubber bushings on my 72 911. I also got the rear swing arm mono balls and just wanted to know what the life is on these do they last as long as the oe? or less?
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
I would be curious too... not just Elephant racing ones but generally, will monoball lasts as long as OE rubber ones?
Are there any tell-tale to indicate replacement needed?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
I'm with Bill
I hope you got the weather packed ones
Electrical problems on a pick-up will do that to a guy- 1990C4S |
The sealed ones (elephant ones) should have good life. As long as the factory ones? Maybe, maybe not. The unsealed ones I don't think will give you the same service life.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
PRO Motorsports
Living with only one testical doesn't have to be a set-back. You can still have a very normal and fulfilling life thanks to advancements in the field of prosthetics.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
But mis spelling will get you every time......
it's.......testicle...... Sorry to have to point that out, but the boys deserve a little respect, no?
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
PRO Motorsports
My, aren't we "teste" today.
Why you gotta bust my balls like that?
