Engine Stand Size
Buying an engine stand to commence a rebuild of my 2.7 motor.
What size (engine weight capacity) stand should I go for? Thanks
1975 911 3.0 Carrera (964 Lookalike Weekender) 1975 911 2.7 (Project) 1979 Ford RS2000 1980 Mini 1275GT 1998 BMW 320i (Daily driver/Reliable Work Horse) |
1/2 ton should do it.
-Brian |
one of gods prototypes
also get one with 4 wheels as opposed to 3, this will make it more stable when you're spinning it upside down and such.
Brought to you by Carl's Jr. |
OK thanks, I am looking at a 1000lb stand with a 4 wheel frame.
Licensed User
The beefier four wheel version will also allow you to get a dolly or a floor jack under the center of the engine whenever the engine goes on or comes off the stand. I bought the 3 leg model and it is plenty stable enough for a 3.2 Carrera motor, its just more of a PITA.
Somewhere in the Midwest
1000lbs 4-wheel model at Harbor Freight is selling for $39 this month...
I went in to get another stand at my local HF store and thought I was going to pay the $59 on the tag....then it rang up for $39! I have the identical stand which I have been using for a couple of years. It's held up to several rebuilds including a couple of very heavy Turbo engines ![]() |
Souk, do you use the official adapter ring for your stand or did you fabricate your own? Thanks!
Brian |
MAGA
Brian, while not ideal due to lack of clutch removal access, here is one I quickly fabbed up out of scrap angle iron, 1/2" bar stock and a few pcs of steel tube. It worked great for all but clutch removal and the price was right
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Tim,
Nice stand adaptor. Much better then the one I spent $130 on. You should sell these!!! Wish I could have used. Don |
Geez Tim...I don't think that thing will hold up a fully assembled engine
![]() ![]() Brian, I have both. I've use the stand with a yoke and the ring. |
Tim, excellent work and a great low-cost solution. Thanks for the pics. I'm filing this thread for future reference.
Brian |
MAGA
![]() Someone gave us a roll of the fabric reinforced plastic/vinyl, I think it is some kind of cheap wall covering. Anyhow it works great as table liner for oily repairs or for when we have a fly-in party and need to turn the work benches into food tables ![]() The problem with selling something like this, is that it would not be very profitable to build in relatively small quantities.
I also have that HF engine stand. It currently has an 83 turbo engine (fully dressed) on it using the Porsche adapter ring which slides right into the engine stand.
It doesn't seem like the sturdiest setup but I don't see it going over. |
HI my engine stands are on www.mbporsche-engineering.co.uk i could send you the sizes of the stand and you could make one your self, will take 3.3turbo/3,6 C4/2 engine no prob'
regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
