replacing steering wheel and wires
I recently replaced the steering column bearing. Not recommended, however I did not label the wires on the turn signal and wiper arm. Where do I plug the wires in? I have a Haynes manual it does not indicate where the wires go?
Old 05-18-2006, 11:48 PM
wcc wcc is offline
wcc's Avatar
I'm not sure on the wiper switch, but I did replace the turn signal once a few years ago. It seems like I remember it had a large plug on the end. It runs down your steering column and plugs in by the ignition under the dash. I know for sure one if not a couple of the stray wires plug in to the back of the ignition switch. Then there probably one for ground. You should start seeing where they go once you get under there.
I hope some of this helps, but don't hold me to it cause I just don't remember EXACTLY where everything goes.
Anytime I do a project like this I take pictures, write down my own diagrams with wire colors, or if it is really complicated I'll group wires together with zip ties and/or labels. Just some ideas for next time.
Good Luck!
Bill
997.2
Old 05-19-2006, 05:17 AM
