I need to drop my 996 tranny in Houston.....>
any locals know a good place to have this done so that I can
send it off to get it fixed???
TIA,
- Cam
If there are no dogs in Heaven, then when I die I want to go where they went.
-Will Rogers
1999 996 FOR SALEhttp://forums.pelicanparts.com/3788325-post1.html
Old 04-19-2006, 07:20 AM
Never been to texas so not much of a help for a garage.
Whats wrong with the trans. I thought they were solid transmissions.
Old 04-19-2006, 07:59 AM
The tranny will not stay in 6th gear....pops out when power is applied.
I knew this when i bought the car & am now in a position
to have it fixed......I have gotten one quote so far of $540.00
to R&R the tranny....(6hrs. @ $90.00).
Stan at "Powerhause" told me it was either the shaft sleeve or a dowell pin that needs to be replaced....... max of $1500.00, but I
gotta send the tranny to Colorado.
-Will Rogers
Old 04-19-2006, 08:07 AM
David's Avatar
I recommend Lawell Motorsports 713-871-1040
Old 04-19-2006, 08:12 AM
I talked to Terry.......VERY COOL!!
May just let him look at it......thanks
-Will Rogers
Old 04-19-2006, 10:37 AM
bivenator's Avatar
dam cam sorry to hear you are down. when you get her back lets see if we can get the spring texas pelicans together for a nite run. nite because it is so hot
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 04-19-2006, 12:05 PM
David's Avatar
Don't be put off by Terry's gangster persona. He's a great guy that knows his stuff. You'll probably see some lambo's and ferrari's in his shop because he treats his customers and their cars right. He drives a wicked fast 996TT.
Old 04-19-2006, 12:09 PM
Well actually I am not down. The car was purchased with this problem (hence the good price) & I have just not been using 6th.
I am just now in a position to fix it before it gets worse, but thanks for the thoughts.
I am ready for another run............
Thanks David......
-Will Rogers
Old 04-19-2006, 12:10 PM
Rick Lee's Avatar
Is this Eli's former 996 from VA? I know this car. I used my 6th gear in my 993 for the first time about two weeks ago. I wouldn't bother fixing it. You'll never use it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-19-2006, 02:07 PM
Yes, it is.....
I guess we drive faster in Texas.....I could use it almost
every day......
Besides, 5th gear 6th gear share components & I was just told it would eventually fail as well & become stuck in gear (this info
is from Stan with "Powerhause Gears")
EDIT: Besides, we dont get in as much trouble if we go over
85mph like Ya'll in VA, it's just a ticket & not "reckless driving"....
-Will Rogers
Old 04-19-2006, 02:27 PM
Any more suggestions............
-Will Rogers
Old 04-20-2006, 05:23 AM
Rick Lee's Avatar
While you're in there, get the gears shortened. Or just swap it for a Euro gearbox.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-20-2006, 06:21 AM
Actually I meant "any more shop suggestions".
I wish I could afford to swap out my gearbox, but that does
not seem likely at the moment.......
-Will Rogers
Old 04-20-2006, 06:28 AM
David's Avatar
I know of more shops, but I don't recommend them. I don't know of any up on your side of town.
Old 04-20-2006, 11:17 AM
I have a guy I go to kinda close, but I felt kinda weird taking it to him to remove, but then not do the work to the tranny, as we had discussed him doing the repairs months ago....maybe it's just me.
-Will Rogers
Old 04-20-2006, 11:45 AM
jmz jmz is online now
jmz's Avatar
Mike Callas in Sealy TX. Rennsport.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 04-21-2006, 01:45 PM
6 cylinder symphony
Mike or Warren at Rennsport is definitely the man to call if you are close to Houston. The only drawback is that he is located about 50 miles west of downtown Houston. But - totally worth it.
Old 05-19-2006, 11:07 AM
MBEngineering's Avatar
HI just drop the trani' your self, at least the engine has NOT to come out??? and the car is not parked up at a garage pos blocking a lift
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-19-2006, 12:59 PM
