JAPPY's Avatar
Removing Fuel Odor
I've just discovered about 1 litre of fuel splashing around in the cabin!!! i know how it got there & it wasn't my fault!!!
But how do I quickly get rid of the overpowering smell - ideally without removing every single bit of carpet?
Michael
MichaelJapp
'71 911E
Old 05-21-2006, 01:58 PM
cygtoad's Avatar
Michael,
I don't think you really have much of a chioice than to remove the affected carpet. The question is, can it be salvaged.
I would start by getting as much fuel up as I could with some rags which you intend to dispose. Then laundering the carpet by hand with a scrub brush and some dish soap. You will probably have to wash it many times before the smell will come out. I would plan on doing the same to the floor boards although those should clean up much easier.
Leave the windows open as long as you reasonably can to get rid of the residual smell. Fuel vapors have probably already traveled to other parts of the car. Airing it out will help.
Sorry I can't offer a more convienient solution for you.
Good luck.
Matt
_______________________
Unless you change your course, you are likely to end up where you are headed.
'87 Carrera, Black on Black
Old 05-21-2006, 05:16 PM
Make Bruins Great Again
Por_sha911's Avatar
Water doesn't do much for getting rid of gas smell (they don't mix). Get the carpet out, soak up the liquid, put something on there to dry it out and then shampoo the drying agent out. In the meantime, air out the car and keep away from open flames.
Joe
Old 05-21-2006, 05:28 PM
jerry marsh's Avatar
Proceed with caution gasoline vapors are so easy to ignite!
jerry
Old 05-21-2006, 08:07 PM
S2GART's Avatar
I don't know if this would help, but possibly a large container of Baking soda to help absorb the odor. It may take some time though.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 05-22-2006, 05:26 AM
