DGW DGW is offline
Shipping wheels with mounted tires
Has anybody done it? If so, are there any problems with doing so that I might want to know about?
Did you use UPS? They are the easiest for me to use. The wheels are 8x16 fuchs if that might have any bearing on shipping.
how did you pack them?
Dennis
Old 05-20-2006, 01:51 PM
Type911's Avatar
Al Reed & Harvey Weidman both have shipped wheels w/ tires mounted to me via UPS. To protect the face of the wheel they
place thin sheets of foam over the rim, then place cardboard (cut to cover the wheel over the foam. Tape wrapped over tires to hold the protective cover in place. Thats it.
Never received any rims damaged when shipped this way.
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 05-20-2006, 01:58 PM
Licensed User
Shuie's Avatar
24x24x12 boxes. Figure $25 each via ground after they are packed.
Old 05-20-2006, 01:59 PM
KNS KNS is online now
Tire Rack does it the same way Type911 described - via UPS.
Kurt
Old 05-20-2006, 02:05 PM
DGW DGW is offline
Thanks everybody.
This sounds easier that I expected.
Dennis
Old 05-20-2006, 02:51 PM
The cost depends on the weight and the size of the wheel/tire package..I have shipped my 18" wheels/tires quite a few times to kinesis and it usually cost around $55 for 55LBs weight..
Later
Old 05-20-2006, 03:37 PM
Round cardboard circles work fine. Ship them in singles. If a package weighs over about 70 lbs there is an excess weight charge tacked on. It might be worth your while to check into fed-ex or DHL. $10 per package savings adds up when/if you have 4 packages.
Old 05-20-2006, 03:55 PM
