-   -   Part Number for 1971 Clock (http://forums.pelicanparts.com/porsche-911-technical-forum/283970-part-number-1971-clock.html)
t6dpilot 05-21-2006 07:36 AM
Does anyone know the part number for the clock in 1971 911's? I am looking to buy one to replace an inop clock and the part number is 911.641.701.29. I just want to be sure before I buy it. BTW anyone know what the going rate is for a working early 911 clock? Thanks much!
jstobo 05-21-2006 08:49 AM
Send to North Hollywood Speedometer. They will replace the clock mechanism with a new quartz and restore your bezel and glass. Not cheap but if you want to keep the OEM look and have a good working clock it is the best way. OEM clocks are NLA. You can buy reproductions but the cost is probably similar to repairing yours. Good Luck.
javadog 05-21-2006 09:10 AM
901.641.701.00 is the part number for a '71 clock. The number you supplied is correct for '74-89.
JR
t6dpilot 05-21-2006 09:30 AM
Thanks Guys! I think that I will go to North Hollywood Speedometer and repair the original. As always, the Pelican members are the best!
project 911 05-21-2006 10:51 AM
My 71 clock didn't work when I got the car. I took it apart and found a fuseable link that had let go. Just a solder joint that melts in place of a fuse. Re-soldered and it has worked fine every since. Just a thought.
