Steering wheel bolt torque
Hi All,
Does anybody know the correct torque setting for the steering wheel bolt on an '84 Carrera? I've done a search and have seen a figure of 36 lbs ft mentioned, but in the Haynes manual it quotes a figure of 54 lbs ft. Do any of you know a definitive figure for this?
Many thanks for your help.
Charles
'84 911 3.2
Old 05-21-2006, 08:42 AM
holtjv's Avatar
Charles--don't know if this helps, but my SC (1979-83) manual states 36 ft lbs and 54 Nm (newtonmeters). Maybe the 54 you're referring to is actually in Nm and not lbsft. Jack
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 05-21-2006, 09:18 AM
Charles,
The spec is 50 Nm which is around 37 lbs-ft.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
holtjv's Avatar
actually, it was 50Nm. Jack
Old 05-21-2006, 09:19 AM
That's great - thanks guys. I think the Haynes manual is probably inaccurate - it tries to cover too many years I think. I'll torque it to 36/37.
Thanks again - you both been a great help.
Charles
'84 911 3.2
Old 05-21-2006, 09:44 AM
I've used 36 for a couple years, wheel hasn't come off in my hands yet.
One thing to remember - DO NOT torque against the wheel lock. Have a buddy or use your feet/knees to hold the wheel against the loosening/tightening torque. You'll damage or break the wheel lock otherwise.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 05-21-2006, 10:04 AM
Thanks - that's a useful tip - I'll make sure I have the keys in the ignition to the first notch to take the steering lock off.
Charles
'84 911 3.2
Old 05-21-2006, 10:24 AM
