Hello P-drivers,
Could anyone explain me why my car brakes when i turn right ?? Is there something wrong with the brakes or with the rear suspension system. Grtz, Bfast
I'm with Bill
Maby you have the rare and illusive Nascar 911. If so it will only turn left.
It sounds like you have something rubbing on one of the front tires. Look and see if you can find the telltale marks.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
If one of your tires is rubbing, you should be able to hear it.
Try to reproduce the problem, and pinpoint the source. It could be you have a brake caliper sticking? Need more details.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Still Doin Time
Tire rub or your flex hose (brake) is failing internaly. Best guess though is tire rub
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Thanks for the quick response,
I think it's a brake caliper ... . What to do now .....review caliper.... Rudi |
Have you removed the wheel and checked for rubbing?
Have you jacked up the front to see how the wheel spins? Checked for a sticking caliper? Caliper rebuild kits can be purchased from our host, and I would recommend doing both fronts. Rebuild kits are inexpensive. I would also replace the flex caliper hoses per asphaltgambler. While you're there, might as well do rebuilds on all four corners, fresh hoses, fresh fluid.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Platinum Member
Have you checked the wheel bearings? If you jack the car up, do each caliper work ok independanylt?
Are you sure it's braking? Could the alignment be so far off there is tire scrubbing wen turning? (rear toe?)
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
