brackets/fittings to install external oil cooler/lines
Hi,
I think I've got most of the pieces needed to install an external cooler on my '77.
So far I've got the two brass lines, a trombone cooler, and two lines that are half metal, half rubber. Want to check and see what else I'll need before I start drilling. I think I'll need:
3 regular brackets
1 front bracket
1 rear bracket
8 rubber insulators (could I just use inner-tube from a bike tire?)
1 bracket to mount trombone cooler to inner fender.
Is this a complete list? Are there any less expensive substitutes?
Also, do horns have to be relocated to install the trombone?
Thanks!
1977 911S Targa 2.7
Old 05-20-2006, 02:31 PM
randywebb's Avatar
search up the thread I posted re oil lines and you'll see some p/n's and photos (for a '73 - may be close to yours) -- it is a month or or two old but no more.
yes, inner tube is just fine.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-20-2006, 02:42 PM
Pkaaso's Avatar
I am going to install the same cooler and lines on my 74' soon. I just want to follow along with your progress.
Paul
If you aint breakin' it, you aint racing it hard enough!
1974 911 3.0 Euro Sahara Beige/Black
Old 05-20-2006, 06:12 PM
Licensed User
Shuie's Avatar
Call Chuck Moreland at Elephant Racing. Just tell him what you have and ask him to send you whatever else you need. And then post the detailed parts, counts, etc. here
Old 05-20-2006, 06:20 PM
hmmm, after looking at some of the prices for the simple brackets etc, I have decided to evade paying some of my Porsche-taxes.
The plan now is to use a cut up old bicycle inner tube as an insulator and to make some brackets like the real porsche ones using generic pipe hanging metal stripping from Home Depot ($5 for 100 feet). The pipe hanging stripping is only 28 gauge, so I plan to double or triple layer it, after bending it to fit, and will attach with stainless sheet metal screws.
Will post if I run into any problems and will snap a few pics.
1977 911S Targa 2.7
Old 05-21-2006, 07:52 AM
klaucke's Avatar
Try a dismantler for the brackets, I think they are worth it although you could hold the lines up with a different method. I did this upgrade to my car last year and used inner tube (from a motorcycle, thicker than a bicycle inner tube) to insulate the line from the brackets. Its quite straight forward and easy when using the factory stuff. I got my stuff from Dan Petchel (sp?) at Cars Inc. in NJ and it was quite reasonable.
Old 05-21-2006, 08:06 AM
vash's Avatar
there are plastic washers, well, cylinders that act as spacers for the rockers, you will need 5 brackets total, one to hang the tbone cooler (most of the tbones i have seen still have the bracket attached). i dont remember rubber isolator bushings on the tbone cooler. you horns do not need to be relocated. there may be one or two more brackets that hang up the lines in the rear of the wheel well. i would find used factory ones. the fit is way better.
poof! gone
Old 05-21-2006, 08:20 AM
randywebb's Avatar
vash - got a pic or p/n for those plastic washers/cylinders ?
Old 05-21-2006, 10:48 AM
Banned
Dave, Good luck on the project. If you want pics of inside of fender where trombone hangs, lemme know. Mark
Old 05-21-2006, 02:45 PM
