Opinions - calipers new vs rebuilt ?
I have to replace my front A calipers on a 78 SC track car.
Check prices on New and rebuilt. I am lenaing toward NEW but hesitated because they are significantly more expensiove vs rebuilt - ($280 vs $50 each) It is a track only car - anyone have experince with rebuilt? I know there are differences in what is "rebuilt" and I am worried that these cores are getting old - Can they replace the cylinder and pistons. How can they replace the pistions and sell for $50? Thanks Earl PS - want to stay stock.
78 SC Coupe 93 RSA (Gone) |
Banned
How bad are your existing ones? if the pistons aren't pitted and the bores rusty - I'd frankly spring for a rebuild kit and DIY. I redid all 4 corners for less than $50 in parts not counting fluid. - it's an o ring and a dust seal. Just hand tools, an air compressor to blow out the pistons (don't use your hand to catch 'em!!!) and a Motive power bleeder and you're on the road.
Don't seperate the caliper halves - just blow out the pistons. Save some cash for more important stuff. |
I'm with Randy P. I had calipers that were dragging on the rotor and made a bad noise after the car was warmed up. A $10 rebuild kit for each caliper solved a problem that I thought was going to co$t a lot of money.
'83 Porsche 911 SC Cabriolet |
Ditto on rebuilding, piece of cake, plenty of data here.. If you're going to spend the big $, upgrade to a 4 piston caliper, larger rotors, new wheels....
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
thanks for the replies.
I already did rebuild the calipers last year. The pistons were questionable - well that question has not been answered. I was interested in exp with buyinh the so-called rebulit calipers. I must stay with stock calipers, etc. thanks Earl
woops - the question on the pistons has NOW been answered. Sorry for the typo.
