Hydraulic tensioner Install
the car has 70 K mi.and I have reviewed 101project info, bently manual ,and Waynes 911 Engine Re Build book to prepare to install the Hydraulic tensioners.
I have dry fitted the oil lines and small oil line bracket jigsaw puzzle(Waynes 911 Engine Re Build book shows it very clearly)
reviewed position of ramps and i will also install the oil line restrictors which supposedly reduce foaming and increase oil pressure. Hpopefully this will not induce any oil leaks in the case ???
The topic of "while you're in there" ...removing the cam wheel sprockets and replacing the o-ring and paper gasket behind them came up.
Question is, Is this necessary and then worth the effort to reset timing which i am not competent enough to do.
What do you guys think? I am not inclined to go this deep.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 05-24-2006, 05:29 AM
If you remove the cam sprockets, you disturb the cam timing. If you do that job (replace o-ring and gasket), you must reset the timing.
Old 05-24-2006, 05:35 AM
David's Avatar
If you don't remove the sprockets, you need to have a wrench on them and make sure they don't jump when you remove the tensioners.
Old 05-24-2006, 05:52 AM
Kantry Member
oldE's Avatar
Don't touch the cam sprockets.
As it advises in Wayne's Tech Article, move the engine to TDC before you start. This will reduce the tension on the valve train. Use either wedges between the case and the chain on the cam sprockets to prevent the chain from slipping off or simply use a zip tie to keep the chain from loosening when you remove the tensioner.
Wayne indicates the distributor will have to be removed, but I replaced the oil lines without having to do that.
That part is not a hard job. I wouldn't mess with the rest unless you were tearing down the top end.
Les
Best
Les
Old 05-24-2006, 07:03 AM
that's TDC #1. very important. if the thrust plates are not leaking, you don't need to mess with them.
206 637 4071
Old 05-24-2006, 08:08 AM
John, David, 125,old e THANKS !!!
I will not venture in to replace o rings and gaskets( i may be asking for trouble)as my engine case is dry. As far as the thrust plates?? i will have to do some homework here since I do not know how to inspect them.
Also, I just checked 101 projects and Wayne does advise TDC but not TDC on #1 Thank You John, and why is this impt??
Bruce
HB Kramer
Old 05-24-2006, 08:41 AM
Kantry Member
oldE's Avatar
If I recall John's post from last week, TDC #1 relieves some of the strain on the valve train.
Les
Best
Les
Old 05-24-2006, 09:52 AM
