CIS strange idle issue
On my 80SC I had a funny idle issue start happening the other day, the car starts and runs fine cold control pressure is exact to spec, warm control pressure is great as well. After starting the idle sits around 950 and then after driving a bit it's up to 1900 or so. If I shut the car off for about 60 seconds and then restart it stays at 950 for the rest of the time. Any thoughts?
Idle mixture is .6% +/- .2%
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Designer King
I would look into vacuum leaks, especially @ the decel valve. Your AAR may also be faulty. It's also possible your distributor isn't advancing correctly, or your throttle linkage is hanging up on something. If you search you will find out how to test for leaks, plug the decel, test the AAR etc.
BTW are you reqd by CO to run that lean?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Try pulling the vac line off of the decel valve.
Our host sells new decel valves if that turns out to be the problem. Apparently there is also a way to "fix" the later SC decel valves by crushing them slightly. Do a search on the forum to find more details on that process. Good luck!
Check the floor mat so that it's not nudging the gas pedal. Hey, it worked for me at one point.
78SC coupe, Silver Metallic |
It's been 200 miles since I re-installed the motor and rebuilt the CIS, so I should probably go back and tighten all of the clamps again. I also base lined and set the AAR tonight, I froze it and then knocked the pin in a bit to get the gate closed, and so that's working better as well. Maybe I am being too picky here, someday I hope to drive or ride in another SC just to see how it's supposed to actually run.
