valve adjustment
Could someone please tell me what should be the average mileage between valve adjustments, and what the average cost is in the NE. I had one shop quote me 700.00. I thought this was insane. I am pretty decent with a wrench, so how difficult is it to do. Also, what is the worst could happen if they aren't adjusted properly. thanks
Billy Crawford |
It's not that difficult on most 911's, although you neglect to include what model of car you have.
If they are too tight, you can burn a valve, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
The going labor rate in my part of the world is around $100/hr that's a 6 3/4 hour job with a $20 part cost. That seems a bit excessive.
At any rate it's a DIY, get two sets of gaskets the first time as I bet you will be going back in on at least one of the exhaust valves. I see many people using the valve adjustment tool listed here at Pelican, I however heated and bent a regular feeler and it worked great.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Immature Member
I think the biggest challenge in valve adjustment must be the access to the valvetrain itself. I haven't done mine yet, but I have checked the sparkplugs and there is NOT a lot of room between valve covers and engine bay walls.
BTW: if one were to err in adjusting clearance, would it be more prudent to have a bit excess valve lash (say .12-.15mm) than have them too tight? I realize the motor will not breath as well, but at least the valves will fully seat. I would hate to be responsible for my car needing new valves and seats because I overtightened the rocker screws. I'm probably frettin' over nothing as I'm sure I'll turn the crank over 10 times and recheck the valve lash until I've broken my last feeler guage!
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
reply
sorry I fail to mention that my car is an 88. I have Wayne's book and it seems pretty much cut and dry. I guess I'm a little hesitant, being it will be my first time.
Billy Crawford |
Re: reply
The valve adjustment job is easy to do, but requires a lot of fingertip feel. The hardest part is tightening the locknut without overtightening the adjustment screw. I developed a feel for backing off slightly from the correct gap, then when I tighten down the locknut, the adjustment screw is at the perfect gap.
Check, check, and recheck the gap before moving on to the next cylinder. My mechanic will adjust my valves and change oil for $90.00. |
I did my first valve adjust a few weeks ago with no problems. I used a regular feeler guage that I bent to fit under the rocker and with some help from a fellow Pelican we were done in about 5 hours or so.
If you are a fairly good wrench ........YOU CAN DO IT!!!!
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
This method proposed by Doug ( 2.7Racer) is absolutely brilliant -->
valve adjustment Everyone should read and study this....it would make valve adjustments MUCH easier and predictable.... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Registered Usurper
In SOCAL, my mechanic, excellent shop, +/- $250.00 (based on $90.00/ hr.shop rate). Works out to be less than 3 hr.s labor - I'm mechanically disinclined, so thats what I pay.
'82 SC RoW coupe |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
$700.00 is INSANE! Check around opr do it yourself.
Ben
1986 3.2 Carrera |
