Rennch on YouTube
Early Car, Late Engine Oil Plumbing Issue
Hi folks,
I've run into an oil plumbing issue with my project. I am putting a 3 liter from a 79 911 into my 69. The oil tank on the 69 has threaded male fittings for the oil lines. The engine-mounted BEHR Cooler on the 79 engine has a press on/hose clamp male end sticking out. So, I have threaded on one side (to a 30mm thread), and a press on on the other. How have others adapted to this? Currently, I have a 90 degree 30 mm to AN adaptor I can use, which I can get a barbed fitting for, but it's only about a 3/4" ID hose, which is too small to press onto the BEHR Oil Cooler. Any thoughts? Thanks, mto
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
I would rather be driving
Two methods.
1. install the early engine oil cooler on the 3.0. 2. cut the firewall and install the later oil tank. This method makes it easy to install later oil cooler lines and thermostat. You will want to supplement the cooling for the 3.0. The engine oil cooler will not be enough in the summer. I guess it would be possible to weld late fittings on the early oil tank but that is a lot of work.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks Last edited by jpnovak; 05-22-2006 at 11:16 AM.. |
You an use an early style oil cooler, or a late style oil tank to obtain the proper match.
You might also check with Clewitt Engineering. I think he might have some sort of adaptor.
Chuck Moreland - elephantracing.com - vonnen.com |
Rennch on YouTube
Thanks guys. I'd like to avoid removing the oil cooler as the engine is installed and wired at this point. The drag about replacing the tank is that I've already completely flushed and POR-15'ed the 69 Oil tank. But, I'll do what I have to, I suppose. Chuck, how do I reach Clewitt engineering?
Rennch on YouTube
It looks like the later Oil Tank is the way to go, so maybe I'll try to find one locally first.
mto- replied to your pm.
"Rust never sleeps" |
Rennch on YouTube
I went ahead and got the later model oil tank, which requires a little slicing and dicing of the firewall. I'll post some pics to document if anyone cares...
