Securing Brake Ducts
Both of my brake ducts came loose after 3-4 days at the track, costing me a bunch of track time. They pulled off from the hub backing plate where they were secured by ty-wraps. The plate is 2 1/2", but the hose is 3". Is there a better or easier way? It's very tight to get anything around those plates.
TIA, John
1985.5 944 GTS |
I've had good luck with hose clamps. Craig
80SC |
John--you should be able to find 2 1/2" hose that fits that size backing plate perfectly. I use radiator hose clamps to secure the hose to the backing plate. Seems to work pretty well.
1980 911SC Targa 3.6L |
Air Medal or two
3m 5200
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
