Carburetor option's for a 3.6????
I have been all over the map lately as to how to get my 3.6 long block
up and running without buying are factory intake.
I have considered TWM's and JENVEY's even PMO's carb set up .
But damn.....There all over 3g's + the aftermarket EMG. That total's easily
4.5g's+.
Any opinion's on using a set of old webbers with a adapter from 2 bolt- 3 bolt style. Or is the spacing of the cylinders too wide to even consider such a possibilty.
I am really in the dark when it comes to what is possible with the flat six.
In Anderson's book...Carbs still seem to give pretty good performance
Old 05-22-2006, 01:08 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
You can do carbs, sure. Weber 46IDA will work with adapter manifolds that have 3 studs instead of 2. If I was dying to do carbs on a 3.6, I'd probably use PMO 50s if I had the bucks...then again, I'd probably look into EFI at that price. PMO's are basically bolt-on $3k. Webers $2k ish...I am working on boring out a pair of Weber 40s to become Weber 46s, perhaps larger, might be a little cheaper than actually buying 46s. Not sure yet.
Best of luck
Scott
Scott Kinder
kindersport @ gmail.com
Old 05-22-2006, 01:15 PM
Cool....
Scott if you can keep me updated on your carb project. I will PM you later today
Anybody else have any opinion's on carbs on a 3.6. I am pretty tempted to keep it old school if they can be reliable.
Old 05-29-2006, 09:30 AM
