swa911's Avatar
Pressure Plate bolts,,,too long?
I am replacing my rubber center clutch with a spring center disc on my 87 G50. In process of installing the pressure plate I am running into a problem where the pressure plate bolts are going all the way through the flywheel and bottoming out on parts of the motor.
I am using the same internal wrenching bolts that came out with no washers.
I did have the flywheel resurfaced at a reputable maching shop.
Am I doing something wrong? Do I need a shorter bolt or can I add washer(s)?
And yes, the clutch disc is installed. I just knew someone would ask that.
1978 911SC #737 "D" Class Club Racer
Old 05-29-2006, 08:52 AM
swa911's Avatar
NEVERMIND!!!!
How about a starter ring gear? It really helped when i put the ring gear on.
Now excuse me while I go kick myself in the ass for being stupid.
I'm just glad I caught it before someone replied.
Old 05-29-2006, 09:18 AM
