-   -   How can I make my turn signal "Latch" better? (http://forums.pelicanparts.com/porsche-911-technical-forum/285326-how-can-i-make-my-turn-signal-latch-better.html)
Gogar 05-28-2006 06:41 PM
I removed my turn-signal assembly on the steering column for a little cleaning and a solder-fix. Anyway, I cleaned the contacts up and greased it a little. Put it all back together and everything works great, except:
when signal to turn right, the switch does not "latch" very well, so I have to hold it up there, or keep pushing it up when it falls down.
Has anyone had this experience and fixed it? Did I grease it too much? Is there a tab I could bend or a little adjustment I could make?
Gogar 05-29-2006 04:20 PM
bump
Emission 05-29-2006 04:34 PM
My "new" switch does the same thing. I just write it off as a "feature" of twenty-year-old technology...
diabolos88 05-29-2006 05:01 PM
yep, its just old tech. I cured mine by switching to the new turn signal, but you will need to buy a washer/signal for the rightside as well since the new turn signal wont match the old style washer/signal.
Gogar 05-29-2006 09:47 PM
Well it bugs me, but It doesn't bug me $300. Thanks anyway.
