Sun roof and windows open with key or not?
I can't for the life of me remember if I need my key in the acc position to operate the windows and sunroof.
I dropped my engine to change the clutch and now I can open both without the key. Is this normal? |
If I did not open the doors (or the door sensor did not ground) then the windows and sunroof function after the key has been turned off. As soon as one of the doors ground then it's a no go, and I need the key on the accessory position again for them to work.
I woulld REALLY like to see a diagram of how this works! Good luck. |
| All times are GMT -8. The time now is 05:00 AM. |
