Using shop compressor as a/c vacuum pump?
I thought I read somewhere that I can use my little garage compressor as a vacuum pump when doing a/c work. Is it as simple as connecting a nipple to the air input side of the compressor with an adapter to fit my a/c manifold, and then connecting it to the low side of my a/c system?
If this is "do-able," it seems to me that a 3hp compressor will do at least as good a job as the smaller specialized vacuum pumps, but I'm interested to hear from some of the a/c gurus on the board. (Jim Sims, are you out there?) |
I have a vac pump that runs off of a compressor. It is the only way I now about doing it the way you are refering to. These pumps are fairly cheep and small. Might just be worth your time to buy one instead of rigging something. You don't need gauges to use this pump but doing ac work without them is not cool. (pun intended)
Thanks, Jim!
Autozone offers a vacuum pump under their loaner tool program! The price is right!....FREE!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92475 |
It would be nice if it wasn't so dang loud. |
I might also add I only use my vac pump at home. When at work I use the big'ol 4 wheeled unit...............................I quess that should tell me something. I guess back to the origional question, no you can't use a compressor as a vac unit. Sorry for the thread jack. :) |
Venturi vacuum? I'd love to see one. Lordy, I'd think you'd need a rotary compressor and some serious volume to accomplish such a feat. Goes to show you what I know about engineering. |
| All times are GMT -8. The time now is 09:42 PM. |
