Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Firing up newly installed engine. Oil pressure question.
Hi...I have just filled 'er with oil, and popped the coil wire off. I turned the ignition, and the oil pressure went up. How far up should it go?
I just want to make sure I'm ok before I go for it.
Thanks.
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-29-2006, 08:51 PM
I think its a good idea to pull the fuel pump fuse also so it does not water down the cylinder walls.
As for oil pressure probably max around 1bar
Old 05-29-2006, 08:57 PM
Rennch on YouTube
rennch's Avatar
It looks like I'm getting about 30 PSI on my gauge. Does that sound right?
Michael O'Neal -
Old 05-29-2006, 09:03 PM
Jubbie's Avatar
That sounds good to me.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 05-29-2006, 09:09 PM
Your set to go if you ask me..... 30psi on a cold cranking motor is perfect.
Just keep an eye on that gauge after it fires.
Good luck
Old 05-29-2006, 09:13 PM
Retired Member
Charlie V's Avatar
I recently did this with mine before firing it up. Got 3 bars with starter motor only cranking for 15 to 20 seconds.
Please note - as part of some engine improvements, I installed the oil restrictors Wayne sells. These will increase oil pressure. The engine idles cold with ~4.5 bars. Once to full operating temp it idles with ~2.5 bars. Anything above 3000 rpm, it has ~4.5 bars.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Rennch on YouTube
rennch's Avatar
I don't know Bar/PSI...but if 30 sounds good to you guys, then I feel pretty good about it.
Michael O'Neal -
Old 05-29-2006, 09:24 PM
Rennch on YouTube
rennch's Avatar
Oil Pressure is good...fuel is in, but no dice. So, it's back to the wiring diagram tomorrow. Night!
Michael O'Neal -
Old 05-29-2006, 10:10 PM
