-   -   B&B headers install heat backdate question (http://forums.pelicanparts.com/porsche-911-technical-forum/285540-b-b-headers-install-heat-backdate-question.html)
johnnyo 05-29-2006 08:04 PM
I will be installing a B&B header w/heat but only has heat outlets towards the front part Trans side of the engine, assuming I remove the rear most heating ducting and engine compartement fan assymbly will I lose the defrost heating?
What areas of the heat are covered by the rear fan assymbly also what additional sheetmetal will I need once I remove the rear heat setup, I did a search and no wherewas it indicated what eat was affected, Thanks
