Outer rocker panel alignment
Hey guys I'm installing new outer rocker panels on my 70 911E
and have some question about alignment before i weld them in. I have a restoring book and the info it gives me is that that bottom door gap should be 4MM. What about the the door gap to the 1/4 panel? and should the 1/4 fender panel be straight in line with the rocker and door? Close up pics will help a lot. I believe the rear 1/4 fender panel is straight and in line with the rocker panel and door. thanks for the help Chris |
| All times are GMT -8. The time now is 02:23 PM. |
