-   -   what does it take to get turbo calipers to fita 74 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/285975-what-does-take-get-turbo-calipers-fita-74-911-a.html)
matty74 06-01-2006 02:32 AM
Hi there,
I have a set of turbo calipers 80 model I want to put on my 74. apart from the rotors what else will I need to o to get them to fit?
cheers
Matt
NY65912 06-01-2006 03:47 AM
Fronts will bolt up no problem. It's the rotors that have to have special hats so everything lines up. The rears need machining to fit, but rotors go right on after removal of the dust shields and cutting off of the ears for the shields.
Turbo brakes should only be done in pairs.
Do a search, there is plenty about this subject.
Check out Bill Verburg's homepage for his wisdom. Vehicle Craft, Instant G.
gumba 06-01-2006 08:51 AM
Go here for more info.
http://www.vehiclecraft.com/Brakes/930_upgrade.htm
Steve@Rennsport 06-01-2006 09:14 AM
Matt:
You need:
Front
Factory 930 caliper bolts, spacers, and wave washers.
Factory short brake lines from the caliper to the struts
Custom front flat-hat rotor assemblies (several suppliers of those)
Rear
Machine work and modifications to rear 930 calipers.
Custom spacers.
Factory bolts and wave washers.
1 ft long brake line bent to fit between caliper and boss on top of trailing arms.
Remove rear dust shields and their mounting bosses
Factory 930 rotors
23mm Master cylinder kit
Turbo brakes should ONLY be done at all 4 corners due to brake bias issues.
Enjoy,
DW SD 06-01-2006 09:31 AM
I believe you also need the appropriate 23mm master cylinder, assuming you are asking about the complete system, rather than just the calipers / rotors.
Doug
TRE Cup 06-01-2006 10:05 AM
you don't need the 23 mm ; the 19mm gives you a longer pedal as the pads wear, but the modulation (pedal feel) is excellent with the 19.
also you need to make sure you have 3.5" bolt spacing on the caliper mounting area on the front struts. 74 911 came with 3 inch (M caliper), 74 911S and Carrera had 3.5" (S alloy calipers as stock)
VCI can help you with the rest
NY65912 06-01-2006 10:11 AM
Take a look, VCI kit.
http://forums.pelicanparts.com/porsche-911-technical-forum/263991-turbo-brakes-vci-oh-yeah.html?highlight=NY6591
Cheers
matty74 06-01-2006 07:42 PM
so I can't just do the front end with a turbo brake upgrade I have to do all four corners.
I was hoping to start with I could put turbo on the front and leave the rear stock until I have enough coin to do the rear.
Bill Verburg 06-01-2006 07:45 PM
No
Yes, and the master cylinder
matty74 06-01-2006 07:59 PM
where can I get the rotors the veichlecarft ones are a bit out of my budget being its for street use what is a more cost effective option?
randywebb 06-01-2006 08:29 PM
Carrera brakes are the more cost effective option. You will experience bling reduction however.
matty74 06-01-2006 09:07 PM
I want to go cross drilled for cooling I have 15" fuchs so they won't be visible anyway.
I don't want to spend uber dosh but I don't want cheap ass crap niether, and maybe a little bling.
vash 06-02-2006 07:48 AM
mentally prepare yourself for that lower rear caliper fastener. it gets way harder to access. on the kit i worked on, it was a 10mm allen you needed to get into there.
Shuie 06-02-2006 08:31 AM
How wide are your tires? 15" fuchs will show the cross drilled turbo rotors fine, but you are not really expecting cooling issues on the street, are you? Are you going to install the booster assembly? Nothing wrong with wanting bigger brakes just to have them, but this mod is 100% the equivalent of bling on a narrow tired street car.
They are a lot of 'gee whiz' things that can be done to these cars. I have suspension bits on my car that are there because I want them, not because they have any advantage over anything else. I wanted the big brakes for my car for a while, but I never could justify this mod in the end. I went with the Carerra setup with the slotted rotors and it was/is over kill for my car on the street. If I had to do it over again, I would probably step down slightly to an SC setup just to save some more money.
matty74 06-02-2006 02:05 PM
So I can put on carrera brakes? do I have to do it all round or can I get away with just the front? What Year carrera brakes can I put one.
Also my engine (2.7l) will be putting out around 240 bhp (webers, ge 60, ssi, je 10:1 pistons) so will the carrera braking be enough?
Bill Verburg 06-02-2006 02:20 PM
x-drilling and slots are not for cooling
Use Carrera fronts only, both rotors and calipers. Leave the rear stock. There will be a small increase in thermal capacity. For street use it won't make a bit of difference. But neither would the 930 brakes in that milieu
Shuie 06-02-2006 03:11 PM
What Bill said. I used the Carrera fronts only with a new stock 19mm master cylinder. Its a bolt on deal. Easy. If I could do it over again I would go with the SC calipers & rotors to save some money. Either is more than adequate for the street. FWIW, you don't want to use the Carrera rear calipers because you wont have the proportioning valve. Just use your stock calipers on the rear, or maybe a set from anything up to an SC. If you are going to be doing track work, the Carrera fronts would be considered an upgrade.
matty74 06-02-2006 03:52 PM
Cool, many thanks fellas you proberbly saved me a few bucks, the Carrera option it is.
If the drilling and slots are not for cooling whats if for?
Bill Verburg 06-02-2006 04:54 PM
gas and fluid evacuation
matty74 06-02-2006 09:00 PM
Can I put Boxster Calipers on a 74 911?
randywebb 06-02-2006 09:09 PM
Dept. of Redundancy Dept. has declared that answer redundant.
randywebb 06-02-2006 09:35 PM
BTW...
Bill - Can he use the Wilwood Billet Superlight Calipers? Are they any good? He'd at least save a few lbs. and gain bling.
