Why do people tunr their gauges sideways?
I'm just curious if there is a reason for this or is it just because you can?
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 06-01-2006, 08:45 AM
durn for'ner
livi's Avatar
Is this a trick question ?
Apparently, during cornering in a swift setting, track days for instance - the dials are obscured by the wheel. You want a clear sight of the red line between gears.
Markus
Resident Fluffer
Carrera '85
Old 06-01-2006, 08:52 AM
Oh Haha's Avatar
Some aftermarket steering wheels hide the important numbers on the gauges. Turning them makes it easier to read at a glance.
Pacific Blue
Wayne
Old 06-01-2006, 08:53 AM
gchappel's Avatar
I rotated the tach so that redline is at 12 o'clock. Especially on the track it was easier to glance at the tach and see how close it was to vertical- I didn't have to try and read the numbers.
I rotated the speedometer so that 50-80mph were easily visible as my steering wheel blocks out some portions of the speedometer.
Those were my reasons, their probably are some others as well.
ymmv
Gary
Usually to have all of them point one way (up) for normal conditions. Race cars are set up this way so the driver only needs a quick glance to see that all systems are well.
Looks like 12:00 is just before redline.
Some people like to have all of the gauge needles pointed a certain direction when they are at their normal reading, for example all of them facing up, or all of them exactly horizontal, when the readings are where they should be. In the case of a tach, most want the needle pointing up at the shift point. That way, they can better read the gauge needle positions using their peripheral vision. Anything that is abnormal is easier to spot. Sometimes, they are moved because the steering wheel blocks the view of a certain portion of the guage.
Sadly, there are also wanna-bes that do it because they see it done on race cars.
JR
Old 06-01-2006, 08:56 AM
Par911's Avatar
Because you have a bent neck......
either that or you drive your car on the track.
Old 06-01-2006, 08:57 AM
ok, I thought that the reason was because the steering wheel blocked parts of the gauge but i wasn't sure.
Currently own:
Gone but missed:
Detomaso Pantera
Old 06-01-2006, 09:08 AM
Doug&Julie's Avatar
Exactly. The picture below doesn't quite show it (the camera was closer than my eye view), but my steering wheel obscures the all-important 60 - 90 mph sweep, meaning I had no idea what my speed was while driving on the highway. So I rotated it about 30 degrees. I also rotated my tach the same...partly to match the speedo but also to keep the "sweet range" at the top of the gauge.
Edit: I can't find a recent picture with the change...sorry.
Doug
'09 Boxster 2.9 PDK
PART OF MY SOUL: '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 06-01-2006, 09:10 AM
I'm thinking I might rotate mine too because it is difficult to see the 60-90 MPH range
Currently own:
Gone but missed:
Detomaso Pantera
Old 06-01-2006, 09:20 AM
durn for'ner
livi's Avatar
I am thinking are we all sitting to far from the wheel as compared to what Porsche intended ?
Seems the first corrections a lot of track newbies need to do is to move closer to the wheel. Its easy to adopt a laid back, comfy, one hand on the wheel style..
Markus
Resident Fluffer
Carrera '85
Old 06-01-2006, 09:24 AM
Back in The Day, I understand that I lot of the formula.Indy car guys would rotate their gauges (pressures, temps, tach) so that when all was optimum, the gauges all pointed up or straight ahead. That way a glimpse was all you needed to know how things were doing.
Old 06-01-2006, 09:25 AM
easier to see then when you're eating that taco.
206 637 4071
Old 06-01-2006, 09:37 AM
Historical factoid.....
early 911 steering wheels were bigger ( 420 mm) than the later ones like the mid 80's ( 380mm or 15"). This smaller size obscured portions of the gauges. Plus, to compensate, the "stock" Porsche steering wheel is mounted off-center.....sitting "high" in the straight-ahead position. Same reason. Those who go smaller ( 350 mm) get the double whammy of obscuring more of the gauges AND having the wheel attach normally...NOT sitting high in the straight ahead position.
All that leads to the ( IMHO) kludge fix of rotating gauges. A more "factory" approach ( although $$) is to have folks like North Hollywood Speedometer recalibrate and re-face the gauges to do the same thing as "rotating", but with the numbers correctly oriented. Then...even your turn signal arrows point ( as intended) left and right..instead of up and down !!!
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-01-2006, 09:50 AM
Is it possible to adjust the height of the steering column? Raising or lowering it to match a driver's height?
(possible, meaning reasonable without carving, welding, etc.)
Old 06-01-2006, 09:55 AM
Jbabic's Avatar
Im chineese...
Old 06-01-2006, 10:00 AM
Eric, I don't know of any good way to raise the height of the steering column without a fair bit of work. However, if you use an extended-hub steering wheel, or spacer to move it closer to you, you'll raise it a little, relative to the seat.
JR
Old 06-01-2006, 10:19 AM
Momo offers an offset adaptor...does the same thing....but only a little.
- Wil
more --> http://www.pelicanparts.com/techarticles/911_930S_wheel/911_930S_wheel.htm
Wil Ferch
Old 06-01-2006, 10:23 AM
304065's Avatar
Wil, which 911 had a 420mm wheel? My '66 is only 400.
The reason you rotate the gauge is to signal subsequent owners of the car that you autocrossed the living snot out of it. If you rotate the gauge back they can still tell because the butter knife you used to loosen the gauge left a bunch of nicks in the rim.
'66 911 #304065 Irischgruen
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-01-2006, 11:15 AM
phiba's Avatar
My mother was driving my dad's 356 once, and was stopped for speeding. She explained to the cop that she was busy trying to keep all the needles (tach, speedo, etc.) pointing in the same direction. I guess the cop didn't know what to make of it, so he let her off.
78 911 SC
89 Range Rover
91 318IS
95 Ducati 916
86 Cagiva Elefant
5 bicycles
Old 06-01-2006, 11:29 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
