Headlights - H1 vs H4
The PO replaced the stock headlights in my 84 Carrera Targa with the Bosch H1 Halogen Headlamp Upgrade kit (0-301-811-004). Apparently Pelican once stocked these units but they no longer are available.
In researching the many Headlight threads I saw a comment that suggested I was fortunate to have these units, as they no longer can be obtained. But the light output doesn't seem that great to me. I am wondering if I should replace them with H4 headlights. What are the pros/cons of the H1 versus the H4? TIA. Carl
84 Carrera Targa - Red |
Keep searching....experts like Warren have, I think, posted with solutions. I think the H1 setup is fine, nd you can upgrade the bulbs. Might want to check the reflectors and internals for pitting or discoloration, as well as the lenses for chiping and opacity.
also, if you decide to upgrade the bulbs, a relay setup is imperitive as the stock switches are over taxed as it is. Also, try Daniel Sterns lighting website for great info and even some parts. Many have traveled this road, there's lots of info out there.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Jake gives good advice but the *major* advantage of H1's is the ability to *separately* aim the hi and low beams. Rather unique feature...which helps explain the desirability and high re-sale cost.
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 06-02-2006 at 01:15 PM.. |
Carl,
Did the PO install relays to carry the lamp drain current??? Depending on how long the H1s have been in service ... the reflectors and lenses may need cleaning, and the lenses may need replacement if pitted severely. Also, the bulbs may be clouded over ... something you can check while you have the assemblies out for cleaning and lubrication of the adjusting screws ... a premium moly grease such as Valvoline SynPower Synthetic Grease #985 or #986 is what I recommend for the adjusters. If rust or corrosion is present on the adjusting parts ... it must be removed with 9% pickling vinegar, Zud or Bar Keeper's Friend, or Naval Jelly! Pitting introduces dispersion into the light pattern and any dirt collected in the pits can reduce light output if the number is high enough! Replacement lenses are still available, thankfully! A bit of preventive maintenance can extend the useful life of Bosch headlight assemblies indefinetely ... which can be victims of neglect in humid climates or if used frequently in rainstorms!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Still Doin Time
Use Sylvania Silverstar bulbs. The light is very bright to blue/white. Great improvement over other halogen lamps
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
