2.7 updated chain wheel support - what to look for
Hi,
How do I know if a 2.7 ('77 911S) has the updated timing chain wheel support? Photo's would be great! Thx much! Al S
Al Shkuratoff 86 Carrera, SW chip, Fabspeed, M&K 83SC Platinum - Sold 83SC Slate Grey - Sold |
Pull the cover and look. You'll be able to see if it has the spacer or the wider Carrera idler arms/ sprocket support.
Wayne's 911 Rebuild book on p159 has explain and pics.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Here's a visual.
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
great pics
Excellent! Thank you all very much!
Al
Al-
Hope that helps. Like Ronin said, you'll have a spacer on the big shaft that is the same material as the tensioner (bright silver) and about 3/8"-1/2" wide.
