window switch help please !
hi guys on a77 911 driver side window switch Ive got the wires mixed up. Could someone post a pic to show the correct way they plug in?. Its the left side main one that work drivers side window . At this point Iam blowin fuses. Thanks in advance !Chuck
This is timely. We just fixed a buddies car that had the wires misrouted and had the same problem.
This info I took right from my Bentley manual. On the switch there are numbers assigned to each terminal: Black to # 1 Grn to # 2 Red to # 3 Brn to # 4 Two red wires hooked together go to # 5 Hope this helps. |
Thanks Man ! I will give it a shot
Hi Oh driverside work now .Pass side gos down but not up? could you post for pass side? thanks !
These should cover the rest of the window wiring for ya.:)http://forums.pelicanparts.com/uploa...1149469237.jpg
http://forums.pelicanparts.com/uploa...1149469285.jpg http://forums.pelicanparts.com/uploa...1149469377.jpg |
Yes!!!! I'm not the only one who mixed up the window switch wires:)
Mike |
| All times are GMT -8. The time now is 05:55 PM. |
